Turbo Pulsating
Old Sep 29, 2008 | 02:13 AM
jeremypulver's Avatar
Default Turbo Pulsating
Hello friends i noticed for that last couple weeks when i give my 01 s60 T alot of throttle my power seems to pulsate like every other second. Seems like the turbo kicks on and off?? Any input would be very much appreciated. Thanks.
Old Sep 29, 2008 | 02:47 AM
D_Jack's Avatar
Default RE: Turbo Pulsating
every once in a while... like about every 2 tanks of gas i will have a few moments through second gear where mine doest what you are talking about.. i think its form crappy gas my opinion.. cuz if i get 93 octane from sunoco or Thorntons it doesnt do it but anywhere else it will cut out every once in a while..
Old Sep 29, 2008 | 09:05 PM
SeanSinger11's Avatar
i think i no wat u mean, i drive a s60 2001 2.4t and when i floor it, sadly yes i do. it cuts in and out from 5k-7k
Old Sep 29, 2008 | 11:54 PM
D_Jack's Avatar
yep thats exactly the RPM range when mine cuts out.. but only intermitently.. its not like it does it every time.. and if i drive it hard for a longer period of time it quits doing it for a while...
Old Sep 30, 2008 | 06:34 PM
Does the check engine light flash when it is cutting out?
Old Oct 1, 2008 | 12:09 AM
No the check engine light doesnt come on at all. I just feel the power loss, then boost, then loss ect.
Old Oct 1, 2008 | 08:54 AM
It might be misfiring.
Old Oct 1, 2008 | 10:51 AM
xman03's Avatar
Might be time to replace your turbo control valve, fuel pressure sensor might be at fault but would typically throw codes.
Old Oct 1, 2008 | 12:55 PM
Yeah, I was thinking it might be the TCV. I will try to get one ordered and see if that fixes the problem. I dont haveany codes or "messages" showing up so... Thanks for the help!
Old Oct 2, 2008 | 02:09 AM
Is there a way to test the Turbo control valve and is the "boost control valve"the same thing? Do you know a good place to order one is?
Old Dec 16, 2011 | 08:24 AM
jacob088's Avatar
i have the same issue with my 07 s60 except my rpm still goes up but i hear it coming from the timing belt area?
Torre1
Nov 22, 2011 11:20 AM
DCCOF1977
Jun 21, 2011 06:52 PM
dougandlisa
Nov 17, 2010 10:55 PM
dsorgi
Jul 18, 2010 10:10 AM
gertjanvandenhoeven
Sep 26, 2008 04:00 AM
