Unexpected Effects of Front Axle Replacement
Old Sep 29, 2010 | 09:09 PM
bobinyelm's Avatar
Default Unexpected Effects of Front Axle Replacement
Some time ago, I commented (whined profusely) here that my new-to-me '01 S-60 T5 w/ 103k miles I'd bought from a nephew had a handling problem.
It would follow every line or irregularity in the road, and while it predominately pulled to the left, the steering wheel (if let go of) would move all over the place, sometimes darting to the left, and then the right. VERY unnerving!
If this wasn't enough, the ride felt like the front struts were welded solid and every road shock was being transmitted to the cabin.
I was HATING the car, and was thinking about selling it (except given the $16k in repair receipts that came with it told me most systems should last quite a while, since so many had been repaired or replaced, including a new $4700 transmission, and a fresh dealer timing belt change only a few thousand miles earlier).
Virtually EVERY front end component had been replaced by the P.O. (motor and transmission mounts, struts, upper strut bushings/bearings, lower control arms, inner and outer tie rod ends), yet the car seemed very unstable.
Then one day, the car started "thumping" on right turns, or even slight right-of-center positioning of the steering wheel. It felt like a wheel was loose on the hub if I had to describe the feeling/sound.
Very occasionally, when coming to a complete stop, I'd feel a "thunk" as if an engine torque mount was bad (but they'd been recently replaced) and like the engine was shifting slightly.
I couldn't think of much except the front axles (half-shafts) as a reason for the thumping.
Upon changing both axles, the "thump" AND the "thunk" were both gone, and the handling settled down to where, except for the drift to the left (still there), the car rides and handles BEAUTIFULLY and responsively.
I would not have believed that the half-shafts could possibly have made that big a difference in so many ways. It's like a NEW car, and an absolute pleasure to drive.
If you are experiencing ANY of the symptoms I was, you might look into the axles.
When removed, the old axles both "felt" fine, with free movement, and no lost motion in the inner or outer CV joints. The ONLY flaw was that the right inner boot (covering the tripoid CV joint)was torn, but the rollers were free turning, and the axles were both free to slide in/out freely w/ no binding or "catches."
I couldn't get NEW axles locally (I would have preferred new), so I went for lifetime remanufactured axles from O'Reilly (who assured me they had no come-backs) at only $60 each, exchange. Naturally, the Volvo dealer quoted $900 and change for EACH side for the job, so it was no contest doing it myself.
The right side took about 2 hours (it was the first side I did, so I was unsure), and the left side took only one hour, with no "special" tools required. Overall, it was a nice way to save $1700 in an afternoon.
Bob
Old Oct 26, 2010 | 10:15 PM
jcoudrain's Avatar
Default Axles
I am faced with the same thing. I have the axles, but I am not sure of the procedure to change them. Will the struts and springs be involved in the axle replacement?
If you could let me know the basic steps you took, that would be great. I can't wait to get them changed.
Thanks
06 S60 T5, 130,000 miles, ASpec 18" wheels.
Old Oct 27, 2010 | 10:45 PM
bobinyelm's Avatar
Piece of cake, really.
1) With weight on wheels, Loosen lug bolts 1/4 turn, remove wheel center cap, and loosen axle retaining bolt.
2) Jack vehicle under center front cross member, and place a jackstand under each side.
3) Remove wheel/tire assembly.
4) Remove Axle retaining bolt.
5) Compress brake caliper piston 1/8" and remove brake caliper assembly and suspend from spring w/ a stiff wire.
6) Remove rotor retaining bolt and remove rotor, and brake backing plate.
7) Remove ABS sensor from steering knuckle and secure out-of-the-way.
8) Using a socket and dead-blow hammer, tap axle inward as far as possible.
9) Mark outline of the upper bolt on the aluminum knuckle (it is slightly elongated for camber adjustment), then remove both bolts retaining strut to steering knuckle, and pull knuckle outward off strut.
10) Pull steering knuckle as far outward as possible while pushing outer axle inward out of hub bearing. There is plenty of room for the axle splines to clear the knuckle by maneuvering the knuckle at an angle.
11a) RT axle: Remove two bolts securing the axle bearing retaining clamp, then pull axle free of the transaxle, being careful not to damage transaxle seal.
11b) LT axle: Using pry bar, apply pressure to "pop" the axle free of the transaxle. There is an internal "C" clip that retains it in the transaxle. Then withdraw axle from the transaxle, being careful not to damage seal.
Note: There is a dust seal between the outer CV joint and the unit hub bearing that should be removed and inspected prior to re-use. Note orientation on removal so it can be correctly re-installed.
Replacement is the reverse of removal. Apply grease to axle splines and left axle retaining clip prior to installation.
Note: If you wish to replace unit hub bearings at the same time (which for $90 per side I recommend if you have 100k+ miles on the bearing), remove the 4 bolts retaining each hub to the steering knuckle (preferably with an impact wrench), and install new hub bearings prior to re-assembly of axles.
Hope that helps!
Bob
420DL
May 16, 2013 05:13 PM
stiebers
Jun 18, 2007 06:08 AM
Mass850
Oct 15, 2005 04:52 PM
teamlfr
Mar 7, 2004 12:48 AM
