Valve seal replacement
Old Mar 17, 2025 | 07:35 AM
RPMCanes's Avatar
Default Valve seal replacement
Can you replace the valve seals without doing a full cylinder head rebuild?
Old Mar 17, 2025 | 09:22 AM
With the head still on the block? Not easily - (remove cam cover/cams. pressurize each cylinder with enough air pressure to be able to compress the valve spring without opening the valve, remove keepers spring and seal, then reverse the procedure) - and valve stem seals are not going to solve your oil usage problem.
Chitownrojo
Aug 3, 2019 03:04 PM
Phil 850
May 9, 2018 07:29 AM
FASTER
Mar 13, 2012 09:03 PM
col
Jan 29, 2007 09:01 PM
col
Jan 29, 2007 04:27 PM
