valve stem seals
Old Mar 13, 2012 | 08:58 AM
FASTER's Avatar
Default valve stem seals
I'm changing my valve's and stem seals, got a 2nd head with good valves, how do I pull out these seals tho? I've tried but only come up with the little O ring spring thing, rubber is still in it. It's a 2000 S80 2.9L
Old Mar 13, 2012 | 09:03 PM
hickman123's Avatar
Once the valves are disassemble and out of the head. They make special pliers to get them out. You could use pliers to get them out too it will just take more work. Just grip the whole seal and pull it out of there they are usually tight. You can use a small socket to beat the new seal back down on. Soak the new seals over night in oil or at least for a bit.
burtongoods
1998-2000 model year XC70
Nov 11, 2013 08:47 PM
rhayles
Oct 24, 2012 11:02 AM
mga56grg
Jan 7, 2011 10:37 AM
col
Jan 29, 2007 09:01 PM
