Vibrating pedal on 2008 s60 2.5t fwd
Old Jul 6, 2022 | 11:24 AM
Coach Asher's Avatar
Default Vibrating pedal on 2008 s60 2.5t fwd
After my trip to California I noticed a slight vibration on my gas pedal when accelerating. It’s been going on for about an month now, I noticed it gets worse as the car gets warmer. It’s pretty slight, nothing violent but does annoy me. Any recommendations?
Old Jul 6, 2022 | 12:20 PM
Do you still have the original front (of engine) mount? And the left side of engine, (front of car) mount is common to sag/leak/tear and transfer vibration.
Old Jul 9, 2022 | 02:29 PM
Default Why would that cause vibration on pedal?
Yes I do still have original motor mounts. When I coast there’s very little to no vibration, it’s only when I get on the gas. Almost feels like I have like 100 micro misfires in a span of one pull from a stop light. I was thinking maybe bent or worn cv axles ?
Old Jul 9, 2022 | 02:45 PM
The right axle when the inner cv joint wears can/will cause a vibration when accelerating at certain speeds - not noticeable when at a steady speed. Your axles are not bent.
Check the mount on the front of the engine - (right side of car) They sag and transfer vibration to the subframe. Easy Diy, after you get the tire off and support the engine.
Old Jul 9, 2022 | 03:13 PM
Okay I’ll order them and get back to you, thank you
Old Jul 10, 2022 | 11:26 AM
I was not suggesting replacement of any part that is not verified to be bad. I was suggesting diagnosing the problem first - for the front mount - take it off and see if the sagging center part is rubbing the subframe. If so replace it. If not - spend your money on something that might actually fix something, or for food, clothing, shelter and retirement.
eoksale
Jul 27, 2021 05:01 PM
Jatchet
Jan 28, 2020 10:02 AM
hu5ker555
Nov 19, 2016 06:48 PM
Forthelove
May 19, 2014 08:24 AM
Micror
Oct 19, 2007 02:23 AM
