were to fill transmission fluid
Old May 30, 2012 | 10:30 PM
mrk3cobra's Avatar
Default were to fill transmission fluid
I have a 2005 S60 T5 turbo with automatic transmission, I would like to drain transmission fluid and replace with mobil 3309. Were do you fill the transmission I cannot find the dip stick or any other way to fill transmission.
Old Jun 1, 2012 | 02:54 AM
J. A. Higgins's Avatar
Old Jun 2, 2012 | 10:39 AM
mrk3cobra's Avatar
I removed the intake to service the PCV system and I found the dip stick down under the turbo hose to the intercooler. 2005 turbos may be different not sure how you would find the dip stick without removing the intake.
By the way I am changing the timing belt with 105,000 miles belt looks great no cracks, tensioner looks good. Timing belt change on the volvo is a very easy job once you find the small slaches on the cam sprockets.
NCS60
Apr 9, 2022 11:54 AM
avapilot
Feb 18, 2011 11:39 PM
jasonl
Jan 28, 2011 11:49 AM
cb1313
Aug 14, 2009 04:42 PM
89 740 turbo
Nov 22, 2008 07:50 AM
