What could euro shops program on a 2002 S60?
First, sorry for the wrong read.
My cars climate control was replaced by the previous owner and I don't know the part # of the original. They didn't program it accordingly hence sometimes it acts funky (won't cool, works better when recirc is ON), but so far it's been working. Also, the person who replaced didn't disconnect the battery and I have an SRS message.
So here's the thing, I called a local euro shop and they said they'd check and program (if need be) the ECC for $85 to make sure the computer works with it properly. I don't know if they can pull (from the computer) the part # for the ECC that was programmed originally. No problem, but my car didn't come with heated seats and the ECC has the buttons for that. Also, it seems my car didn't come with the AUTO recirculation feature, you can only turn recirc on or off (left LED lights up only) and the ECC has the MAN/AUTO button for it.
- Can I get an ECC (that fits) from a salvage that doesn't have the heated seats button and with the manual recirc button and have the shop program it?
- Or could I get one WITH the AUTO recirc button and make that work as well?
- I don't know if I can just remove the heated seats button on mine and replace them with a blank button cover. Then just get the current one programmed.
- Can the bottom row of buttons be programmed as well? Mine just has the Valet trunk lock button and the one for lowering the rear headrests. I've noticed some came with the STC button as well, dunno if I could get one and program it as well.
- My headlight switch doesn't have the fuel door unlock button, could I replace it with one that has it and get it programmed? I've read that the 2001 models didn't have it but 2002 and up did.
- Can you pretty much get any interior controls programmed?
Thanks in advance.
EDIT: I noticed my headlight switch has the fog light button on the bottom right, but there are no bumper mounted fog lights (they're covered up). What will it do if pressed?
Thanks in advance.
If someone put the wrong CCM in, you can't program it to make it work as far as I know. Technically, any used CCM shouldn't be able to be put in that car and work, but it may if you get the correct one.
You can pop the heated seat buttons out and put a blank in. I believe it is available separately.
The bottom row isn't just a matter of adding a button.STC is run through the ABS control module, it isn't just a button.
I don't know what you mean about the other interior controls.
The fog light button on the bottom right is the rear fog light.
Not sure about the fuel door button, I thought all 02s had it as well. What's the VIN?
Does
Does
Does
Does
-I have the CCM off of an XC90 available (work at a dealership that owns a salvage) with the blank button for the heated seats that I could pull out and replace with the dual buttons.
- So can the bottom row buttons be programmed or not? I was able to easily pull them out and reinstall physically from the XC90's CCM. It seems you can plug them in in any slot since they use the same interface/connector.
- Other interior controls as in anything that has a switch, button, ****, etc. (radio, light switches, window switches, etc.) I ask in case I ever need to change out anything that works electrically myself at home.
- Yeah, I went outside and tried the button out, rear fog lights came on. Works perfectly. Should've done that before asking :/
- VIN is YV1RS61R522099286. The fuel door works properly; locks itself 10 minutes after remote lock and unlocks with remote as well.
Thanks.
Your CCM is part number 8651247. Just doing a software reload to this one is likely going to be a waste of money.
The button blank from the XC90 should be the same.
The bottom row of buttons cannot simply be programmed. You can't just add a park assist button and have park assist. You can't just add a button to change the entire traction control system, etc. If there is a dealer installed option for something that uses a switch in the lower row, then it can be programmed. But I don't know of any for an 02 S60.
Lots of things need a download to work, if that's what you're referring to when you asked about getting other things programmed. For example, the door modules (switch packs) need a download to work. A used one won't work.
Your car has an open recall for the fuel pump, I'd recommend taking it in for that.
This is what I found with a quick search, don't see my part#:
2002 Volvo S60 4DRS with Sunroof 2.4l 5 cylinder Auto Parts like heater
I'm taking it tomorrow morning for the recall (appointment), I had checked the VIN for that before I bought the car. Let's see what happens.
I guess I'll stick with my current CCM until a buy a newer Volvo in the future that was properly taken care of.
Thanks a million again.
For now I'm just going to replace the recirculation and heated seat buttons so it looks proper. The bottom row of buttons works correctly so I can leave that be. As long as the Auto A/C works I'm happy.
jessewvu
03-23-2011 07:22 PM
