What oil do you guys use?
Mobil 1 10-30w in the S60 and Mobil 1 High Mileage 10-30w in the V70...........I used to go 5k or 5 months but my new Volvo mechanic recommends doing 4k/4months and that's the interval I'm switching to. On my Benz, I do 5k/5 months but it also has an eight quart oil capacity v. the six quarts on the Volvos.
Per my wife's '06 warranty & maintenance manual, there are a variety of viscosities recommended, but 5W-30 is the "all purpose". Depends, of course, on climate, and towing. Volvo says 7500 miles without differentiation for type of use; but I tend to think that's optimistic. For some reason, the manual and the filler cap both say "Volvo recommends Castrol". And, it adds that syn is recommended for vehicles used to tow.
If you have a turbo, I'd think synthetic is a good insurance policy since it resists "cooking" better than non-synthetic. The oil in the turbo bearing gets plenty hot. And as anybody old enough to remember 1980's Chrysler turbos can tell you, coking of the oil is not a pleasant thing to deal with.
Stick to the factory recomendations on change intervals. They didn't make those numbers up just all ***** nilly.
My experience with oil. And I have torn apart a few motors thats I've built. Its basically all the same. Sythetic is less likely to coke up and or cook off, so therefore it lasts a little longer. BUt other than that its the same as natural oil. There is only one type of oil out there with a vast difference to other oils. Oil for diesel vehicles. Because they are allowed to have a little bit of zinc and some other stuff in their oil that oils for gasoline engines can't have. that being said. I run Rotella Super T, because. It fights against sludge, it has less ash in it, it operates better at higher temperatures, its way less likely to cook or coke, and finally its made for vehicles that don't stop running for sometimes days on end. I put it in my 242TI and I rape that thing no matter what the temperature is.
