What's Wrong With My Brakes??
I own a '02 Volvo S60 T5. A few days ago I noticed a hissing sound coming from the brake pedal area near the floor board. This hissing sound is constant when the car is running. When I turn off the car the hissing sound continues for a few seconds then dissipates. When I press the brake pedal the hissing sound diminishes and if I press the brake pedal down all the way the hissing sound disappears altogether. Obviously air is escaping from something.
I crawled underneath the steering column with a flashlight to see if I could spot the problem. I had the car running while I did this. Here's what I noticed (please forgive me for not knowing the technical terms for any parts I try to describe).
The brake pedal is connected to a black brake arm. About half way up this arm there is a gold rod/bar that extends from the brake pedal arm through the floor board (at least it looks that way). Along this gold rod/bar there is a rubber sleeve that looks like the bellows (folds) of an accordion. It seems like the hissing air is coming from this part. However, as I used my hand to feel all around the sleeve, I felt no escaping air. I depressed the brake pedal several times and watched this part in action and again, the hissing would diminish or disappear completely depending on how hard I depressed the brake pedal.
I don't know what's on the other side of the floor board where this gold rod/bar seems to extend through. Though I got under the hood, then jacked the car up and got under there to look, I was unable to see where the rod/bar came out of the floor board.
Any ideas what could be happening?
So is the part I posted pictures of on this thread the cruise control server? Is the brake master cylinder also on the engine side of the firewall?
grochef
09-08-2005 12:14 PM
