where to buy cheap(er) tranny oil?
Old Aug 22, 2012 | 12:16 PM
Rado001's Avatar
Default where to buy cheap(er) tranny oil?
Hi All,
2 questions here:
1) what type of tranny oil do I need for 2001 s60 t5?
2) where can I buy it so I don't have to pay dealer price?
Any tips are very appreciated.
Rado
Old Aug 22, 2012 | 06:24 PM
BBamKudin's Avatar
use Toyota T IV atf. It's compliant to JWS3309 specs.
Old Aug 23, 2012 | 09:41 AM
eEuroparts.com's Avatar
Former Sponsor
For a manual tranny, this should do
for automatic you can use one of these two. Genuine, Pentosin
Hope this helps!
Old Aug 23, 2012 | 10:46 AM
migbro's Avatar
Hope this helps!
$20.83 and $16.07 a litre? Gosh!
For JWS 3309 fluid for your AW55-50 transmission you have the following options:
Toyota T-IV - 5 to 6 bucks a quart if you buy a full case at the Toyota dealer
Mobil ATF 3309
The following multi-vehicle fluids also meet the JWS 3309 spec.:
Castrol Transmax Import Multi-Vehicle
Idemitsu ATF-HP, available at Cottmann transmission centers
There are more. Any tranny fluid with a "J" in the name is probably JWS 3309 compliant. e.g. Nissan Matic-J. Check the label.
Old Aug 23, 2012 | 10:49 AM
MYS6T's Avatar
If it is an Auto Please Only Use VOLVO JWS3309,mOBIL3309 or Toyota T IV. The fluid is NON-SYNTHETIC and yes there are JWS3309 specs in most ATF but there are many guys that have had issues after the use of Non 3309 fluid.... Toyota dealer is the best place most times.... 14 qts. for a full Drain/Fill flush...
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
Volvo-dealers
Dec 1, 2010 03:21 PM
I8ASaleen
Jul 14, 2010 05:34 PM
cameron
Mar 26, 2008 05:44 PM
Justin325
Aug 31, 2006 08:48 PM
