Would 20" Polestar Rims fit on a 2011 S60?
Old Jan 23, 2023 | 11:28 AM
Snowman1871's Avatar
Default Would 20" Polestar Rims fit on a 2011 S60?
Hi! I'm hoping to get Polestar 20" rims (2015 version, 20x8) for my standard 2011 S60.
Would they fit? Or would there not be enough turning clearance and/or do I have to adjust anything to fit them?
Old Jan 23, 2023 | 12:58 PM
the answer is most likely they will fit - the way to confirm is to look at the specs for the model/years in question at
wheel-size.com. Both years used the same center bore and bolt pattern/style so the only other consideration is rim width and offset.
It looks like the Polestar rims have an ET55 and which is 8mm (.3 inch) more than the ET47 on the 19s offered on the 2011s - that just means the inside of the rim is that much closer to the strut etc but since its an 8 inch rim, it should work
craigclark57
Apr 5, 2015 09:47 PM
TXS60T5
Jun 13, 2013 11:56 PM
Morader
Aug 28, 2011 01:18 AM
bihsoccer14
Jun 3, 2010 04:47 PM
brushfires60
Jun 15, 2005 12:27 AM
