1998 S70 2.4 SE Starting problem
Old Oct 7, 2005 | 11:56 PM
redlight's Avatar
Default 1998 S70 2.4 SE Starting problem
Quite often when I attempt to start car ...starter will rollover but won't engage motor. Wiggle the transmission(auto) and car ussually will start, sometimes stumbles. Could this be PNP or microswitch
Old Oct 8, 2005 | 02:32 AM
Default RE: 1998 S70 2.4 SE Starting problem
If you hear the starter but it isn't cranking the motor then the starter is bad.
Old Oct 8, 2005 | 07:34 AM
alecw81's Avatar
Or it's possible not completely engaged in Park. I know mine used to be a bitch to completely engage into park and wouldn't let me remove the key until I smacked it around a little bit, but I figured it out.
Old Mar 4, 2008 | 05:27 AM
Thecapeman's Avatar
I'm having this issue lately - sometimes when I turn the key I will hear one click and nothing. Repeat abunch oftimes and it will start.
Bad starter? Quirky solenoid?
Old Mar 5, 2008 | 09:34 PM
roadrunvvo's Avatar
You may want to check the grey 'block' starter fuse under the hood. Mine was cracked and not fully engaged with the circuit. I had problems similar to what you described. I tapped on the fusegently (with the handle of a screw driver)and it re-engaged. It still works fine after 6 months. Be careful; if your battery is still connected (as I discovered) you may get a spark or worse--shocked.
Old Mar 6, 2008 | 05:23 AM
Thecapeman's Avatar
Thanks- I did take it out and put back in on first day but will re-check today.
Will also check old(er) cheap(er) battery which came with car. I'm wondering if it may need some distilled water added.
I'm not sure this is starter-related anymore - because it will eventually start - sometimes on the 3rd try, sometimes on the 53rd.
Rick
yanhor15
Apr 27, 2015 01:44 PM
shergar76
Nov 28, 2008 04:55 PM
delsa
Mar 21, 2008 11:35 AM
Nelson
Feb 15, 2007 10:02 PM
starfighter
Aug 1, 2005 02:47 PM
