1998 S70 speedometer not working.
Old May 19, 2020 | 10:59 AM
Poorasdirt69's Avatar
Default 1998 S70 speedometer not working.
I've changed the whole dash cluster out and same problem, odometer/speedometer doesn't work. I do have an ABS light on the dash. Should I spend the money on an ABS tester?
Old May 19, 2020 | 07:06 PM
or more likely spend your $$ on a rebuild of the ABS controller board. The speed sensors go through the ABS board, which are prone to cracked solder joints. Check out Rocha-Tek, Midwest ABS or XeModex web sites for common symptoms of a bad ABS controller. Also you should be able to go to Autozone etc to rent/borrow an OBD2 code reader that can read ABS codes.
Old May 24, 2020 | 11:00 PM
My OBD II reader show no ABS codes.
Old May 25, 2020 | 09:51 AM
Psaboic's Avatar
I second getting the ABS unit tested/repaired........
PMOURASSA
Jan 3, 2017 05:28 PM
afredo
Apr 9, 2014 09:19 PM
beachbumtroy
Nov 19, 2012 08:25 PM
mourassa
Sep 24, 2011 08:15 AM
shoter_hellas
Apr 14, 2011 12:15 PM
