thehacker44 |
03-08-2012 09:24 PM |
1999 S70 awd cranking but don't start
Hi, I have a problem on my 1999 awd turbo s70... engine wasn't runing very well while decelerating and the code was missfire on cylingder 5 so i parked the car and took a look under the hood and found one ground wire for the coil of the 5th cylinder was broken and the coil wasn't working neither... i fixed that by replacing the coil and fixing the wire... i put new spark plug (NGK) and gap them right using alldata and mitchell-on-demand's specs (GAP : 28)... after that i started the car using a booster pack but the car wasn't even trying to start it was just cranking.... (the car was starting well when i decided to change the spark plug and the coils !!!!) I have good fire on each of the spark plug (tested white a spark-tester and was reacting at 35 000 volts)...wire for the injectors are good too they all have power on the green wire... ( im a bit confuse because it was working befor i change the spark plugs and the coil)... is there anybody that has fixed this probleme already?
