2000 S70 GLT SE Radiator Replacement
Old Mar 1, 2011 | 09:50 AM
tomecsi's Avatar
Default 2000 S70 GLT SE Radiator Replacement
It's time for my radiator to be replaced as it has a crack and is leaking. I'd rather replace than try to JB Weld it or some type of temp fix.
Question is: Since I will be replacing radiator, what else should I replace at same time? I plan on replacing radiator, hoses, thermostat. Have I overlooked anything that I should be replacing at same time as radiator?
Where have you guys found the best deals on Volvo radiators?
Also, what is the degree of difficulty in replacing a Volvo radiator? Ive only ever worked on American cars before! Any special, oddball tools required for the job?
Thanks!
Old Mar 1, 2011 | 12:36 PM
I would check with FCP. Also compare with IPD. There are a couple of oil / transmission lines that connect to it. You may want to have a few rubber corks handy.
spacedogb
Oct 3, 2016 07:31 AM
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
jpjmustang
Mar 24, 2014 07:03 AM
Carter124
Sep 2, 2013 10:22 PM
adam blackwood
Jun 9, 2012 09:32 PM
