98 S70 - no spark
Old Dec 25, 2010 | 07:16 PM
wahlspyder's Avatar
Default 98 S70 - no spark
I have a 98 S70 that has been my wife's daily driver for the last 8 months and 25k miles. It usually lives in the garage but with the onset of snowy weather it moved outside and her Subaru moved in. I drove it the other night and it ran great, but went out to start it today and it won't start. There is no spark and I'm not sure about fuel pressure since I don't have a way to check it. Any ideas what to check? Have played with the keyless entry fob and the door locks and the 98 shouldn't have an immobiliser (no chip in the keys). I have checked all of the fuses and find no problems there. I have tried by code scanner, but I have never been able to get it to connect to this car even when it was running well so I can't pull any codes. Thanks.
Old Dec 26, 2010 | 11:32 AM
boostnm3's Avatar
Why do you think there is no spark? If there is no spark, you need to see if its the wires, cap or rotor. A good tune up would not hurt if it hasnt been done recently. Spark plugs also. If you have a gauge you can thread it onto the fuel line and have your wife turn it over and see what kind of pressure the pump is pushing out. Has the car sat for a long time? If so it could be that you just need to turn it over for a good bit to build oil pressure. Volvos are known for this if they sit awhile. No real problem, just lack of oil pressure at the valves. Do you have enough battery voltage?
Old Dec 26, 2010 | 11:50 AM
wahlspyder's Avatar
Sat for just a couple of days. I know it has no spark because I have checked for spark - none from coil or from plugs. It ran great when I had it out a few days earlier.
Old Dec 26, 2010 | 08:44 PM
My guess would be the cam sensor. Does the car crank?
Old Dec 27, 2010 | 11:29 AM
wahlspyder's Avatar
Yes -cranks fine - any way to test cam sensor?
Old Dec 27, 2010 | 11:32 AM
wahlspyder's Avatar
Shift light and the "W" light on the shifter stay on too if that makes a difference.
Old Dec 27, 2010 | 07:20 PM
No way to test it to my knowledge. I would say replace it if you have no spark but fuel pressure.
Old Jan 8, 2011 | 04:21 PM
wahlspyder's Avatar
Ok - verified 42psi at shrader valve so have (I think) correct fuel pressure. Guess I'll order a cam position sensor and see what happens. Thanks
Old Jan 17, 2011 | 06:45 AM
wahlspyder's Avatar
Cam position sensor changed, Volvo lives again! Thanks for your help everyone!
Old Jan 17, 2011 | 04:49 PM
Glad to hear that you are back on the road.
Old Nov 22, 2015 | 11:46 AM
johnhon's Avatar
According to my Chilton manual, you can test the CMP sensor.
"Unplug sensor. There are 3 female terminals. Turn on ignition and, using a voltmeter, measure the voltage at terminal 3 and ground. It should be battery voltage. If it's ok check terminal 2. It should be around 5v. If that's ok test terminal 1. It should be 0 ohms."
The diagram of the connectors in the manual shows the connector curve side up, then terminals numbered 3-1 left to right.
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
rordon
Jul 3, 2008 06:07 PM
dcox612
Sep 29, 2005 09:37 PM
