'98 S70 Won't stay running.
Old 10-09-2018, 04:36 PM
CondorsFan's Avatar
Default '98 S70 Won't stay running.
I have a 98 S70 that won't stay running. I got it with a blown head gasket. I replaced that and it ran great for about three months. Now it will start and run until it reaches normal operating temperature, then it chugs like it's not getting gas and dies it will not restart for several hours after that. There is no odd colored exhaust until it chugs, then the exhaust is white. I an not a mechanic, so the head gasket being bad is a possibility, but any ideas? Thanks in advance.
Old 10-09-2018, 07:30 PM
Test the engine coolant temp sensor.
Old 10-10-2018, 08:35 AM
Psaboic's Avatar
I agree, do a search and look up testing and or replacing the engine coolant temperature sensor. It is not hard at all and not very expensive either. FYI, white smoke is usually a sign of unburned fuel.
Old 10-10-2018, 07:14 PM
tony1963's Avatar
There is a "stay running" module inside the muffler. Sometimes that condensation from the exhaust will cause it to fail.
Order a replacement at 1-800-Stay-Running
Old 10-12-2018, 12:30 AM
CondorsFan's Avatar
A new coolant temp sensor is on the way. Hopefully that fixes it.
Old 10-12-2018, 08:38 AM
Psaboic's Avatar
Keep us posted
Old 10-14-2018, 06:32 PM
CondorsFan's Avatar
Default Update
Ok, so the temp sensor I got from Amazon was the wrong one. I tried to check some stuff anyway. I started the car and let it come up to operating temp. It sputtered again, but it stayed running. I was driving when it died before, so it was under throttle. This time, when the thermostat opened, and the engine cooled a bit, it started running rough, but once the temp came back up, it ran ok. I drove it around for a few minutes and it did fine. So there is a problem, but not the one I thought what could cause that?
Old 10-14-2018, 11:48 PM
jenkinskg@yahoo.com's Avatar
sounds like water leak into head, maybe cracked head
Old 10-15-2018, 08:46 AM
Psaboic's Avatar
Im still betting on it being a coolant temperature sensor. If it was a cracked head there would be evidence of oil in the coolant and white smoke out of the tailpipe.
Old 11-04-2018, 04:51 PM
CondorsFan's Avatar
Default I changed the Coolant Temperature sensor
Sorry updating took so long. I changed out the CTS, which was about three tomes harder than it needed to be. The Torx bolts on the thermostat housing stripped for me. Anyway. I got it put in and will run now at any temp. However it stutters under acceleration, and will die if it sits idling for more than two or three minutes
Old 11-04-2018, 09:01 PM
Psaboic's Avatar
Is the check engine light on? If so, read the codes and we can go from there. Otherwise I would suggest a full tune up with new plugs (Volvo OEM) plug wires, air and fuel filter, and possibly a new coil. Also, I would clean the butterfly in the throttle body.
Old 11-04-2018, 09:57 PM
CondorsFan's Avatar
The check engine and service engine lights are on intermittently. I had the code read and it says it us running rich
Old 11-05-2018, 08:38 AM
Psaboic's Avatar
I suggest getting the codes cleared since you have had a few things already done to the car. Then, if the light comes back on, re-read the codes and that should give us a clue as to what is going on.
Old 11-11-2018, 06:39 PM
Psaboic's Avatar
Any updates? Also, the service light is simply a eminer that the car is due for an oil change. It triggers roughly every 5000 miles after it is reset.
Old 11-11-2018, 06:58 PM
CondorsFan's Avatar
Not much to update. I'm saving money to replace all the plugs, wires, etc... once that is done, I will update again
Old 11-12-2018, 08:34 AM
Psaboic's Avatar
In the meantime, clear the codes for the check engine light and see if any come back......that will be a big help.
Rick62
12-06-2017 12:20 PM
Tiara Brown
12-05-2017 08:45 AM
damianthehusky
02-14-2015 06:38 PM
Fletchcarp
07-07-2010 03:12 AM
Quick Reply: '98 S70 Won't stay running.
