99 S70 AWD won't turn over
Old May 10, 2010 | 01:59 PM
eneff7's Avatar
Default 99 S70 AWD won't turn over
'99 S70 AWD about 130K - have had a couple of weeks - hand-me-down (Thanks Mom!) I've noticed the idle was a little low a couple of times on start up. The problem has been that after driving the car, I've shut it off for a few minutes to run an errand and then tried to start it and it's either not turned over or it has caught and then sputtered out. I typically waited a few minutes and then started the car and drove on my way. This happened 5 times over 2 and a half weeks. This morning, she never started back up. My old 850 Turbo had a similar issue that eventually led to fuel pump replacement after changing the fuel pump relay. Am I on the right track? or should I also be concerned with the Electronic Throttle Module and /or the Mass Airflow Sensor, Idle Control valve? Thanks.
Old May 15, 2010 | 12:41 PM
If the car is not turning over it may be a bad battery???
Old May 16, 2010 | 10:28 AM
eneff7's Avatar
The engine is trying to turn over but it seems like it is not getting fuel. I'm going to swap out the fuel pump relay from an 850 I have and if that doesn't work, I'll replace the fuel pump. Does that sound like a reasonable progression?
Thanks
Gustav
Nov 11, 2017 01:01 PM
reggietre
Apr 16, 2010 09:20 AM
reggietre
Dec 11, 2008 10:20 PM
exotek
Nov 11, 2008 09:32 AM
pmb
Sep 13, 2006 12:15 AM
