'99 s70 stalls at idle and throws an immobilizer code
Old Mar 24, 2009 | 03:33 PM
bentshackle's Avatar
Default '99 s70 stalls at idle and throws an immobilizer code
I've got a '99 S70 naturally aspirated automatic with 155k on it.
At first it would stumble and stall only in heavy traffic after a few minutes. It has been getting worse and now will stall at idle in the drive way, while slowing down to make a turn, etc. It behaves itself perfectly above 1100rpm and when cold.
After stalling it takes substantial throttle to restart/keep it running.
Every time it stalls it throws a P1081 (immobilizer code) from module 7A
I SeaFoamed the throttle body, ran a bunch of injector cleaner through it, gave her new plugs, air filter.
Disconnecting the MAF causes no change in behavior (other than it will also throw a MAF sensor voltage low and IAT voltage low code as well)
Is the immobilizer kicking in at inopportune times?
Any help would be hugely appreciated.
Cheers,
O
Old Mar 24, 2009 | 07:51 PM
The immoblizer only works on start up then it is disabled.
You have another problem. An immoblizer will not stall a car.
The throttle body might be bad.
mstrplmber
Jun 8, 2019 07:18 AM
nkinkade
Feb 28, 2014 08:49 PM
joedogg
Mar 28, 2012 10:19 AM
SirJohnIII
Nov 18, 2010 10:58 AM
rainman14624
Sep 20, 2010 09:22 PM
