aoto transmission
Old Oct 21, 2007 | 08:27 PM
volvogltturbo's Avatar
Default aoto transmission
I have a 2000 volvo s70 glt with 97000 miles and when i put in reverse and give it a fair amount of gas, it jerks like if u let off the clutch too soon on a manual, should i be worried?
Old Oct 21, 2007 | 08:53 PM
Default RE: aoto transmission
You might have a bad engine mount.
Or do you know for sure the transmission is slipping?
Old Oct 24, 2007 | 06:03 PM
no its still steardy, but when i put in reverse, and only when i step on it, it jerks/studeers like a stick, but transmission does not slip
Old Oct 24, 2007 | 06:20 PM
The upper torque mount on the top of the engine might be bad.
Old Oct 24, 2007 | 07:01 PM
thanks, is it bad to shift manualy with automatic?
Old Oct 24, 2007 | 11:43 PM
Volvocars's Avatar
Like from 1-2-D? No most likely not. But why? Ifits a shift-gas-jerk concernthen I would think is most likely a trans issue. But check those mounts first!
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
