bah. i need some help.
Old 11-30-2009, 09:01 PM
thekoopa's Avatar
One of Solders on my relay looks like it is burned. The solder looks brown with maybe a hairline crack in it. I didn't see it when I looked but my girlfriend noticed it. I hate my bad eyes.
  #22
Old 11-30-2009, 09:21 PM
That might be it then. Fingers crossed for you.
  #23
Old 11-30-2009, 11:02 PM
thekoopa's Avatar
Thanks tech! Just ordered the relay from FCP. 10$ cheaper then IPD.
  #24
Old 12-01-2009, 07:18 PM
Cool.
  #25
Old 12-09-2009, 05:31 PM
thekoopa's Avatar
Well I put the new fuel pump relay in on Monday and threw some Lucas fuel injector cleaner in it. Today coming back from my lunch break it died again. I turned it off and started it back up. It ran perfectly fine Monday until now but it was the same situation with the old relay. What else should I try? I don't know how much more money I want to put in this car. Just passed 200k miles and I might just buy something newer.
  #26
Old 12-11-2009, 09:06 PM
Does it act like it is running out of gas or does the tach just drop then the car stops?
  #27
Old 12-12-2009, 09:55 PM
thekoopa's Avatar
It seems like it just shuts off.
  #28
Old 12-12-2009, 10:21 PM
Then it has to be ignition related.
  #29
Old 12-14-2009, 11:01 PM
thekoopa's Avatar
What should I check first?
  #30
Old 12-15-2009, 08:59 PM
Is the plug in the cam sensor good? Or is it falling apart?
  #31
Old 12-30-2009, 04:07 PM
thekoopa's Avatar
Well, I took the car into a Volvo servicer today. They changed the spark plugs and I guess the last person to put a fuel filter in the car installed it backwards. So he put a new filter in aswell, but the car still has the randomly cutting out problem. He says it might be the fuel pump and he wants 350$ for the pump. Do you think I should have the pump replaced? Is 350$ expensive for a new pump?
  #32
Old 12-30-2009, 09:04 PM
That is not all that bad of a price. But he can tell if it is the pump if he drives it with a fuel pressure gauge connected to the car.
  #33
Old 12-30-2009, 09:35 PM
thekoopa's Avatar
He says it had fine fuel pressure but it didnt repeat the problem when he drove it. I was looking on ipd amd they have the fuel pump for around 200 but they have the fuel pump assembly for 400 whats the difference?
  #34
Old 12-30-2009, 09:47 PM
You can replace the pump motor only. But IMO I would do the entire assembly if you can and if it comes to needing a pump. I have seen alot of the plastic assembly's crack and cause leak diag. codes.
But get him to verify it is the pump using the gauge first.
  #35
Old 01-19-2010, 12:03 PM
thekoopa's Avatar
So I've just been driving my car waiting to see if the fuel pump would just quit working. Well yesterday while merging onto the freeway my check engine light comes on. I pulled the codes:
P0300
P0302
P0303
P0304
All misfire codes?
  #36
Old 01-24-2010, 09:57 AM
Yes they are all misfire codes.
  #37
Old 01-25-2010, 10:19 AM
thekoopa's Avatar
Does it still sound like a fuel pump? Anything else I should check before I buy a fuel pump?
  #38
Old 01-25-2010, 08:31 PM
No sounds like an ignition problem. Like a cap,rotor,wires or coil.
  #39
Old 02-01-2010, 11:25 PM
thekoopa's Avatar
Went out today to go mess with the car and my battery was completely dead. I hadn't driven for about a week. Do you thlnk it could be related to any of the ignition problems you listed?
  #40
Old 02-02-2010, 06:40 PM
No it would not be related to that.
Quick Reply: bah. i need some help.
