battery drained
Old Jan 12, 2007 | 11:28 PM
dj296's Avatar
Default battery drained
my kids forgot to closed the door properly for about 3 days, so I guess the red lights on the door was on for about 3 days (the interior light is on off position), is it possible this can cause my battery to be completely drained? I tried to start the car, it won't even turn, the information display on the dashboard went blank and after I take the keys, the info display turn on fully ( 8888, etc, everything shows their full digital track) after about 30 second, it goes normal and the digital clock goes to 00:00
is this normal? or there is another problem with the car? is there anyway I can check the current that the car (ecu) needs from the battery when the car is off
PS: the battery is 1 month old, the car is 98 S 70 2.5 L
Thank you for your help
Old Jan 13, 2007 | 12:32 AM
Default RE: battery drained
Parasitic draw specs. .025 Amps is normal.
Old Jan 13, 2007 | 10:50 PM
dj296's Avatar
ORIGINAL: tech
i'm sorry...what is "parasitic draw" means?
could you tell me how to check the Amps?..I'm afraid if I do the wrong way, I will screw up the whole car electricity
thanks a lot Tech
Old Jan 15, 2007 | 08:26 PM
You meet to get a meter that measures Amps. Set it on the Amp setting. Then disconnect the Negative terminal. Put one lead on the Battery and the other on the terminal.
Then see what the reading is.
Here is a pic of how I do it. If you can do it like the pic that would be great. I do it like this so there isn't much of a spike in amps when hooking the meter inline.
I stick the one probe on the battery terminal and clip the other to the terminal and slide the terminal up onto the other and let it sit.
Old Jan 20, 2007 | 03:29 PM
elbert's Avatar
It is possible you just simply drained the battery especially having the interior lights on for 3 days. Batteries are not at their best during cold weather. Have the battery charged or buy a battery charger. I recommend having a battery charger a homehandy for accidents like this.
Nataku
Aug 19, 2012 09:51 PM
Lulumike
Oct 6, 2011 07:49 PM
axis72
Jan 21, 2008 08:45 AM
colgate41
Jun 28, 2007 07:57 PM
