Broken Turn signal
Old Aug 31, 2006 | 11:30 PM
jkwin7's Avatar
Default Broken Turn signal
Help! My turn signal won't blink or it will blink 2-3 times and then stop. All the lights work. I checked the fuse, which was good. I also tried the suggestion of manipulating the key (ignition), as the weight of the keys can sometimes interfer with proper function of the turn signal according to the advice of the individual. This didn't work. Does anyone have any suggestions before I take it into the shop?
Old Aug 31, 2006 | 11:43 PM
Default RE: Broken Turn signal
Try pushing the Hazard switch on and off and see if that makes them work again. If so the Switch is bad.
That is the Turn signal relay.
Old Sep 2, 2006 | 12:55 AM
jkwin7's Avatar
I tested the flashers and they seem to work fine, but there's still no improvement in the turn signal. Any other suggestions?
Old Sep 2, 2006 | 01:15 AM
What happens when you turn the Hazards on when the Blinker is messed up?
Does it make the Blinker work?
The hazard switch is the Relay for the Blinkers as well as the Hazards.
Old Sep 2, 2006 | 02:16 AM
jkwin7's Avatar
Now my flashers are working intermittently. I assume the relay is going bad. Is this an easy remove/replace job? Any suggested web sites with how-to instructions? I checked Bay 13, which I've used successfully in the past, but didn't see anything on this subject. Any help would be appreciated.
Old Sep 2, 2006 | 11:22 AM
If you slide the Radio out you should be able to slide the switch out from pushing on the back of the switch.
The switch is located just under the radio.
lcocke
2001-2013 model year V70
Mar 30, 2014 05:57 PM
Dennis C
Dec 29, 2009 08:24 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
kirkdavid
Oct 5, 2008 06:31 PM
