CODE,RUNNING LEAN BANK1
Old Dec 18, 2008 | 12:19 PM
chachouu's Avatar
Banned
Default CODE,RUNNING LEAN BANK1
I got this code on my non-turbo s70, what are the possible cause,and which cylinder is Bank 1,one on the left or one the right.
My wires are good and my spark plugs are less then a year old
Old Dec 18, 2008 | 04:18 PM
Default RE: CODE,RUNNING LEAN BANK1
You only have 1 bank.
You might have a vacuum leak somewhere. I would check that first.
Old Dec 18, 2008 | 05:35 PM
chachouu's Avatar
Banned
what,s the easiest way to check for a LEAK
Old Dec 18, 2008 | 05:40 PM
Usually with the car running spray all around the hoses and connections if the idle changes there is your leak.
Also check all the small hoses for cracks where it connects.
Old Dec 19, 2008 | 08:33 AM
chachouu's Avatar
Banned
Spray with what,is water ok.
Old Dec 19, 2008 | 09:00 AM
Carb or brake cleaner works best.
Old Dec 19, 2008 | 05:46 PM
chachouu's Avatar
Banned
thanks, TECh.I found a loose small hose that goes under around the air box filter,I reset the code,how long does it usually take to come back,if that was not the problem to begin with.
Old Dec 19, 2008 | 06:31 PM
It might be one day it might be 2 weeks. It depends on alot of things.
seanq73
Apr 17, 2020 06:03 PM
gilber33
Aug 15, 2010 04:56 PM
peabrain
Apr 4, 2008 07:30 AM
elchingon2002
Mar 11, 2008 10:41 AM
yellow95
Apr 23, 2006 01:54 PM
