Crank no start!!
My 2000 s70 just cut off on me after 3 minutes of driving. My dash board shows a (ETS) warning light!
I replace the fuel pump in which this wasn't the problem! Nor me replacing the spark plugs either!! Can someone please help me!! Like I said she cranks like she wants to turn over but JUST WANT START
ETS light could be a few different things, including the brake pedal sensor! Did you scan for CEL stored codes? Regarding the throttle mechanism, check out sites like XeMODex and Midwest ABS as they have some content on how to diagnose issues with the ETM. You can also try cleaning the throttle body but that's a long shot.
All of the throttle modules used on your year will fail - and can keep the engine from running. Here's a diagnostic from xemodex.
First thing - stop replacing parts that are not bad, it gets very frustrating and expensive. Then scan for codes with a compatible scanner.
https://xemodex.com/us/etm-diagnosti...0-s70-v70xc70/
mooses9
01-10-2016 07:15 PM
