Crank! no start!!
Old Sep 25, 2021 | 08:45 AM
Roc's Avatar
Roc
Default Crank! no start!!
My car completely shut off on me...I have (ETS) warning light that stays constant on my dash as well as a pointed up ^ arrow.....the arrow ^ and the (ETS) warning stays on when I'm trying to start mr car!! It cranks and barks like she wants to turn over but never starts.... I replace the fuel pump in which I see it wasn't the problem because I tested it after it was removed.... plus I ran a wire straight from the battery to the new fuel pump,,CAR STARTED RIGHT UP!! But as soon as I removed the wire car died again
Old Sep 25, 2021 | 09:37 AM
What condition is your fuel pump relay? Solder joints in them crack and prevent current from going to the pump.
Old Sep 25, 2021 | 09:50 AM
Psaboic's Avatar
Try removing the fuel pump relay and putting a jumper wire in its place. this will cause the fuel pump to run. Try starting the car and if it runs and stays running, you have a bad fuel pump relay. Instructions for jumping the relay are here on the forum, just do a quick search. Good luck!
Roc
Sep 24, 2021 10:48 AM
mds2road
Nov 19, 2014 04:32 AM
abracadabra
Mar 9, 2012 09:54 AM
JayKShin
Jan 15, 2011 04:21 PM
kljukusa
Feb 1, 2008 06:18 PM
