CV Axles / Boots
Old Oct 27, 2011 | 07:53 PM
tomecsi's Avatar
Default CV Axles / Boots
While looking under the car today preparing for major front end replacement work this weekend, I noticed my CV boots are shot. What determines if the whole CV axle needs to be replaced or if you can get away with just replacing the boots?
Old Oct 28, 2011 | 08:02 AM
tomecsi's Avatar
OK, if you decide to just replace the boots (inside and outside) is there a way to do it without removing the CV axle?
Old Nov 1, 2011 | 03:16 PM
tr_car_nut's Avatar
If both the outer and inner boots are damaged and all the grease has run out of them then it is a good idea to replace the whole axle. Keep in mind it is rather simple to just replace the entire axle rather then replacing the boots (very labor intensive) but the cost is a little high. And yes you have to remove the entire axle from the car in order to replace the boots (plenty of pounding involved to get the CV joint off the end of the axle).
Sunbeam
Volvo C30
May 7, 2015 08:28 AM
02VolvoS40
Jan 10, 2011 04:04 PM
IsuzuFire
Jun 29, 2010 01:32 AM
Mikenem
Jan 12, 2010 05:04 PM
BRB
Mar 15, 2008 08:27 PM
