Do I need a new Brake Master Cylinder?
Old Oct 27, 2016 | 02:39 AM
Ben_25's Avatar
Default Do I need a new Brake Master Cylinder?
I bled the brakes, brake pedal is stiffer for a few days, goes back to being loose again after a couple days. It's definitely losing pressure. Checked all the lines, etc. 99 S70 with 148k. Most likely original master cylinder.
Old Oct 28, 2016 | 07:53 AM
Psaboic's Avatar
Sounds more like the brake booster and not the master cylinder to me.............Are you losing brake fluid? I'd check all the lines and calipers first.
Old Oct 28, 2016 | 05:56 PM
Ben_25's Avatar
I have not lost any fluid. I just replaced the ABS module due to the original failing and causing me to intermittently lose my speedometer though. Brakes feel a little stiffer, but I want a rock hard brake pedal. It may just all be in my head honestly. Although, the master cylinder may be worn out.
greenbluei
Oct 12, 2025 11:25 AM
michaeltroy
Dec 24, 2014 09:11 AM
J Dubb
Jun 25, 2011 08:11 PM
Beemer2002
Jan 4, 2010 08:14 PM
retroguybilly
Aug 24, 2009 08:41 AM
