Does anyone know the details on OEM fogs?
A buddy pulled a set of fogs from a car in the JY. They do not work. We took the lights, brackets, relay under the fuse box cover, switch, and 2 relay's from under the dash. However, I must have missed something because they DO NOT work. Anyone have the details on this?
After failing on my attempt to swap these fogs it appears that I should have done the following:
1. Pull the fogs w/brackets. 2. Pull the main light switch relay from next to the fuel pump relay. 3. Pull the switch near the shifter. 4. Pull a J relay from under the dash, far left, upper. 5. Pull a jumper wire from the relay panel under the dash. This jumper gives it power. |
im sure you have done the research, thats why im asking, is there anywhere to buy them new? I just need the lights and the brackets.
