Does anyone know the details on OEM fogs?
Old Sep 24, 2012 | 09:59 PM
Default Does anyone know the details on OEM fogs?
A buddy pulled a set of fogs from a car in the JY. They do not work. We took the lights, brackets, relay under the fuse box cover, switch, and 2 relay's from under the dash. However, I must have missed something because they DO NOT work. Anyone have the details on this?
Old Sep 27, 2012 | 01:56 PM
After failing on my attempt to swap these fogs it appears that I should have done the following:
1. Pull the fogs w/brackets.
2. Pull the main light switch relay from next to the fuel pump relay.
3. Pull the switch near the shifter.
4. Pull a J relay from under the dash, far left, upper.
5. Pull a jumper wire from the relay panel under the dash. This jumper gives it power.
Old Sep 28, 2012 | 06:56 AM
Dewaholic1's Avatar
im sure you have done the research, thats why im asking, is there anywhere to buy them new? I just need the lights and the brackets.
jelarf
Jan 27, 2021 03:43 PM
pjfslk
Jan 29, 2007 12:25 AM
cool_kyle_3000
Jul 16, 2006 03:15 AM
gordon368
Apr 9, 2006 03:34 PM
