engine check p1307
Old 06-18-2005 | 01:59 PM
skamil's Avatar
Default RE: engine check p1307
I replaced the A/C high pressure switch.
  #22
Old 06-18-2005 | 08:21 PM
I also beleive the fuel tank pressure sensor is on the same circuit as well.
  #23
Old 06-28-2005 | 07:32 PM
skamil's Avatar
Hi there.
You where right the first time. The A/C pressure sensor was bad.
I checked for the bad code, and then I replaced the sensor, and checked again, in a short period of time (10 minutes).
And it is wrong. The bad A/C sensor caused the ECM (computer) to get hot, and I needed to let it cool down of for an hour before checking it again. The resistance between terminal #1 and 3# on the bad sensor was 8 ohms, and on the good sensor the resistant is very high.
Thank you for your help. You are a real Pro.
Simon
  #24
Old 06-28-2005 | 07:50 PM
No problem anytime.
Im glad I could help.
tngreg
09-05-2022 07:27 PM
wieder
09-10-2010 08:42 PM
logisoft
01-29-2010 08:56 AM
Quick Reply: engine check p1307
