ETM - how "open" should the little door be? And yellow marking?
Old 03-25-2012 | 04:18 PM
volvamos's Avatar
Default ETM - how "open" should the little door be? And yellow marking?
Hi all, there's a plethora of ETM threads around but haven't found my answer. Maybe it's just plain dumb!
2000 S70 - a week after purchase began to choke, sputter and show the ETS light. I haven't driven it in 2 weeks and now no light or symptoms, but I still went ahead and did the clean.
It was simple to remove and pretty much clean as a whistle. Which does worry me that it will have to be replaces once symptoms return.
I've never worked with an ETM before...the little circular door/flap inside isn't flush or fully flat/closed. It is open just a bit, maybe a centimeter or two. Is this how it should be?
Beyond that, I noticed a very small yellow tick (like form a paint pen or marker) on the plastic part of the ETM. Even though I've read that the swapped ETMs involved in the huge recall had a yellow "sticker". Could this still be an indication that it was indeed replaced?
rmcneil
10-01-2015 09:31 AM
kaimal
06-02-2014 01:03 PM
fiat128
04-14-2014 09:09 AM
WongWebb
01-11-2013 08:29 PM
biasbob
01-07-2012 10:44 PM
Quick Reply: ETM - how "open" should the little door be? And yellow marking?
