Fuel PUMP
Old Jul 15, 2008 | 11:23 AM
chachouu's Avatar
Banned
Default Fuel PUMP
I am hearing this pitching noise,at times when I start my 1998 s70 non-turbo,could it be the sign of my fuel pump going bad,and how do I diagnose it.
Old Jul 16, 2008 | 02:52 PM
samadkins29's Avatar
Default RE: Fuel PUMP
could be a belt aswell. I would have the car checked out.
Old Jul 16, 2008 | 06:44 PM
I would have it checked really soon to make sure it isn't the timing belt idler or tensioner pulley.
Old Jul 17, 2008 | 08:26 AM
JRL's Avatar
JRL
S.A.P?
(Secondary air pump)
Makes quite a whining noise when goingbad opon start up, itusually goes away in 2 minutes but still needs to be changed as it will finally throw a check engine light
Old Jul 17, 2008 | 10:57 AM
chachouu's Avatar
Banned
sorry I failed to clarify,the noise is coming by where the fuel pump is located near the gas tank,not by the engine compartment,my timing belt is new.I have no noise whatsoever around the engine.
Old Jul 17, 2008 | 11:53 AM
JRL's Avatar
JRL
Well, since there is absolutely nothing else back there that could make noise, you may as well look at the pump
Old Jul 17, 2008 | 08:49 PM
chachouu's Avatar
Banned
what would be the easy way to know if it,s indeed the PUMP.
Old Jul 23, 2008 | 02:12 PM
jsj_297's Avatar
You can try just turning the ignition key to run position and let the fuel pump prime. While listening near the fuel tank, should be the only thing really running at that point.
rphud
Sep 27, 2014 06:06 PM
spidersilva
Aug 17, 2011 07:23 PM
scrap88
Apr 7, 2010 09:23 PM
montysano
Sep 9, 2008 11:52 AM
