-   Volvo S70 (https://volvoforums.com/forum/volvo-s70-33/)
-   -   Fuel PUMP (https://volvoforums.com/forum/volvo-s70-33/fuel-pump-21563/)
chachouu Jul 15, 2008 11:23 AM
Fuel PUMP
I am hearing this pitching noise,at times when I start my 1998 s70 non-turbo,could it be the sign of my fuel pump going bad,and how do I diagnose it.
samadkins29 Jul 16, 2008 02:52 PM
RE: Fuel PUMP
could be a belt aswell. I would have the car checked out.
tech Jul 16, 2008 06:44 PM
RE: Fuel PUMP
I would have it checked really soon to make sure it isn't the timing belt idler or tensioner pulley.
JRL Jul 17, 2008 08:26 AM
RE: Fuel PUMP
S.A.P?
(Secondary air pump)
Makes quite a whining noise when goingbad opon start up, itusually goes away in 2 minutes but still needs to be changed as it will finally throw a check engine light
chachouu Jul 17, 2008 10:57 AM
RE: Fuel PUMP
sorry I failed to clarify,the noise is coming by where the fuel pump is located near the gas tank,not by the engine compartment,my timing belt is new.I have no noise whatsoever around the engine.
JRL Jul 17, 2008 11:53 AM
RE: Fuel PUMP
Well, since there is absolutely nothing else back there that could make noise, you may as well look at the pump
chachouu Jul 17, 2008 08:49 PM
RE: Fuel PUMP
what would be the easy way to know if it,s indeed the PUMP.
jsj_297 Jul 23, 2008 02:12 PM
RE: Fuel PUMP
You can try just turning the ignition key to run position and let the fuel pump prime. While listening near the fuel tank, should be the only thing really running at that point.
