Fuel Pump Assembly or Insert - Which to Buy?
Old Aug 9, 2009 | 07:17 PM
RobOrtiz's Avatar
Question Fuel Pump Assembly or Insert - Which to Buy?
I found a fuel pump assembly and an insert on FCP. Big difference in price. Is the insert a low cost alternative to replacing the entire assembly? If so, has anybody used it?
Old Aug 9, 2009 | 07:55 PM
Sorry to say but I would replace the entire assembly.
Reasons are:
1. The sealer around where the wires go through the unit falls apart and gas leaks out.
2. They crack by the square hole that is recessed and causes an evap small leak code.
3. Usually there is problems with any insert setup pump.
jojoswhip
Dec 28, 2010 11:28 PM
HunnyBunny
Dec 14, 2010 07:18 PM
dudwash
Jul 15, 2006 11:16 PM
gspregent
Sep 19, 2005 10:31 PM
tech
Feb 24, 2005 07:51 PM
