Gauges help
Old Oct 4, 2008 | 03:47 PM
mal's Avatar
mal
Default Gauges help
Hi guys
I change temperature(coolant) sensor and thermostat and my temperature gauge is still at zero, plus ambient temperature gauge is not working too, check with working one but my gauge is not indicating and from time to time speedometer is turning off. Any help please, is it instrument panel or wiring? Car is 98, S70, GLT,180K milage
Old Oct 4, 2008 | 04:30 PM
Default RE: Gauges help
Is your ABS light on?
If so them the ABS module might be bad causing some of the problems.
Old Oct 4, 2008 | 04:51 PM
mal's Avatar
mal
ABS light is not on
Thank you for reply tech
Old Oct 4, 2008 | 05:02 PM
There still might be codes present though.
How does the temp sensor look? The one in the thermostat housing?
Old Oct 4, 2008 | 05:14 PM
mal's Avatar
mal
1) temperature sensor is at the thermostat
2) I check with working ambiant sensor and my amdiant temperature is not working at cluster
3) speedometer is turning off from time to time
4) my mechanic told me car been hit on driver front site b4 buying
Old Oct 4, 2008 | 07:39 PM
ABS module will stop the speedo from working.
Does the Tach always work?
Old Oct 4, 2008 | 08:27 PM
mal's Avatar
mal
yep
Old Oct 4, 2008 | 08:29 PM
I wonder if it is a bad ABS module.
Old Oct 4, 2008 | 08:33 PM
mal's Avatar
mal
must I buy new insroment panel or can be wires ?
Old Oct 4, 2008 | 08:37 PM
mal's Avatar
mal
fuel,tach,clock always work
It could be many things. If the ABS module is bad it can shut down most or all of what you are having problems with.
But it could also be wiring and lastly the speedo cluster.
Old Oct 4, 2008 | 08:38 PM
mal's Avatar
mal
you guys have chat room and how to register ?
Old Oct 4, 2008 | 08:44 PM
mal's Avatar
mal
never have ABS light on except on start
Old Oct 4, 2008 | 09:00 PM
mal's Avatar
mal
tech tnx for replying give some hint
Old Oct 4, 2008 | 09:08 PM
Might be a good idea to try to have the codes pulled there might be a code even though no ABS light.
If all is good with that then I would be looking at the wiring/cluster. You might be able to find a used one to swap into the car.
Old Oct 4, 2008 | 09:17 PM
mal's Avatar
mal
k, tnx gonna go tomorrow to have the codes
Bummer
Sep 6, 2011 09:58 PM
bli745
Oct 31, 2006 04:02 PM
woodpecker
Aug 12, 2005 07:05 PM
woodpecker
Aug 11, 2005 05:30 AM
KNIN
Apr 27, 2005 07:23 PM
