Help
Old May 22, 2013 | 07:56 PM
Kenzi Perez's Avatar
Default Help
So my 98 s70 had a motor oil leak until a mechanic fixed te drain bolt and it no longer leaks. Well for some reason when I check the motor oil stick it shows below the x's? is it because the car is hot? Or do I have a leak or pressure problem
Old May 25, 2013 | 01:16 PM
FernBchJeep's Avatar
The x's are the safe range. Add enough oil until it is near the top of them then check it every day or so. If the level drops you have a leak that you'll need to locate and fix.
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
