In middle of engine swap now mechanic said might not work?
Hi and welcome to Volvo Forums.
Sad to say that those two motors are very different. First level is turbo/NA, second level is that Volvo made some major changes in the cams in '99 so they are not compatable. If they mechanic told you that, maybe he should pitch in on the cost. What exactly was wrong with your motor in the first place to warrant a replacement? Maybe you can go to U-Pull-It (with the mechanic) and get a motor for $250. |
Originally Posted by knightpony
(Post 335622)
If they told you that engine would work then they are liable for what you spent on it; they need to buy that '99 engine from you for what you spent on it. Then find a reputable volvo indy shop in your area (hint: it ain't these guys!) and take your car there. |
