Hood Latch
Old Aug 20, 2007 | 02:37 PM
carllamar's Avatar
Default Hood Latch
I have a 1998 Volvo S70. When I pull the hood latch only the right side comes up . The left side (drivers side) won't release. Is there anything that I can do to get it to release othere than trying to force it. I trying to change my oil and it's hard to do with only one side of the hood releasing. Also, my AC keeps going to the defrost vent without me sending it there. Does anyone know what's up with that? Thanks
Old Aug 20, 2007 | 04:34 PM
samadkins29's Avatar
Default RE: Hood Latch
yeah my hood does the same thing. Basically I pull the hood latch, then I go to teh front of the car, and pull teh hood up(only aliitle bit), then go back and pull the hood release latch again, go back to the front and I open the hood. Kind annoying, but its not worth the money to fix it since I am not under my hood enough.
Old Aug 20, 2007 | 06:30 PM
Usually if you adjust the latch that opens first down a hair it will fix it.
Old Aug 23, 2007 | 08:28 AM
carllamar's Avatar
Thanks alot for your responses. They really helped me out.
Old Aug 30, 2007 | 10:06 PM
Auburn T5's Avatar
Eh, it's a losing battle. Adjustments will typically only be a temporary bandaid. I've tried adjusting the latches, tightening the cable under the driver's side dash and eventually, you'll eithe rhave to have someone lightly lift on the drivers side of the hood or do what I do which is fold a rag in half and wedge it up between the hood and the top of the headlamp. Basically, you need just enouhg pressure lifting up on the hood by that latch to pop it lose and the rag trick works.
There were a few S70 and 850 guys at the south east volvo weekend all employing the rag trick.
JeannieBeannie
Mar 6, 2019 01:29 PM
850TurboWgnPlatEd
Nov 5, 2008 12:52 PM
dougsnow
Apr 22, 2006 07:07 PM
salkenn
Nov 19, 2005 02:59 PM
trehux
Aug 10, 2004 07:01 PM
