How do I replace the gearshift indicator?
I have a 1998 S70. The gearshift indicator has shifted off to the side and is no longer visible. I know that I need to remove the cover to see what part broke but I am not sure how to do this. If anyone can tell me how to do this that would be great. Thanks.
RE: How do I replace the gearshift indicator?
You need to remove the Center console.
To do so open the Arm rest. remove the cover in the bottom.Then slide the cover for the e-brake handle towards the seat and remove. Remove the 2 screws and lift up the back and slide it out. Then you will be able to remove the cover ane see what you need. |
