How much psi can my engine withstand?
Old Mar 24, 2008 | 05:42 PM
samadkins29's Avatar
Default How much psi can my engine withstand?
Hey all, so Im getting a 16t turbo and was hoping to run 15psi(or higher) on it. I have a 98' glt, mods are in the sig. Am I going to burn my engine? What else could/should be put in?
Old Mar 24, 2008 | 08:18 PM
S70driver's Avatar
Default RE: How much psi can my engine withstand?
For starters you can run 15PSI on the 13g you have now. However 15PSI for the 13g is at the top of the 13g's effeicency range.
The 16t will hold 15PSI much better then the 13g and you can go up to 17PSI safely. Don't think you can run 20PSI and be good. 15-17PSI on a 16t is plenty. It can handle the 15PSI better then the 13g can.
Old Mar 24, 2008 | 08:28 PM
Yea I didnt really want to push my stock turbo with 213k on it. This 16t only has 10k. Either way my main question is, putting 17 psi through my engine gonna hurt it or the exhaust system? In terms of heat.
Old Mar 24, 2008 | 09:12 PM
S70driver's Avatar
You should be fine on 17PSI. However you would benefit from a downpipe upgrade and catback system upgrade. Especially since your upgrading to a bigger turbo.
You are putting more stress on your engine and by upgrading these parts you will lessen the stress your putting on it.
Also how are you going to run 15-17 PSI? MBC or ECU upgrade? I highly recommend the ECU upgrade route it is better and safer.
Old Mar 24, 2008 | 11:39 PM
It will be a mbc for now, ecu upgrade later, I really wont be pushing the car that much. Just on occasion I may launch it.
Old Mar 25, 2008 | 08:19 AM
S70driver's Avatar
ORIGINAL: samadkins29
Why not just wait for the ECU upgrade? That is what I would do anyways.
And as always supporting mods will help you relieve stress on your engine as well as boost your performance.
ENDEE666
Oct 12, 2012 08:51 PM
boggy
Nov 4, 2011 08:22 PM
boostnm3
Jan 1, 2011 05:29 PM
aryanvahedi
Nov 18, 2009 08:59 PM
riaf28
Jan 14, 2006 10:26 PM
