Key stuck in ignition of 99 S70
PLEASE HELP!!!! My key is stuck in my ignition. I Can start car, go from park to reverse etc and shut off the car, but the key WILL NOT COME OUT! I was also able to get the steering wheel to go into the "locked" position and nothing! Please help!
Thank you!:confused: |
Check the sticky, that is a common problem. Also, you can do a search to get your answer.
Make sure the button on the shift knob is out all the way. If it's stuck in even a little bit, the key won't come out. As rspi says, common problem.
