Key stuck in ignition of 99 S70
Old Aug 15, 2011 | 08:27 PM
Lauries99s70Volvo's Avatar
Default Key stuck in ignition of 99 S70
PLEASE HELP!!!! My key is stuck in my ignition. I Can start car, go from park to reverse etc and shut off the car, but the key WILL NOT COME OUT! I was also able to get the steering wheel to go into the "locked" position and nothing! Please help!
Thank you!
Old Aug 16, 2011 | 09:07 AM
Check the sticky, that is a common problem. Also, you can do a search to get your answer.
Old Aug 17, 2011 | 01:50 PM
pitrow's Avatar
Make sure the button on the shift **** is out all the way. If it's stuck in even a little bit, the key won't come out. As rspi says, common problem.
Old Jul 11, 2013 | 10:54 PM
Obelix
Jun 20, 2022 08:40 AM
dodgerkcj
Jul 2, 2018 11:41 AM
rspi
Jul 11, 2013 10:48 PM
rspi
