Knocks from under the car while driving
It is S70. When I drive on a bad road, there are knocks from under the car.
I checked the suspensions and they are functioning properly.
What can I check and how?
Check the front upper spring seats.Get a 13/16 wrench and try to turn the top nut under the hood for the front struts.If it turns it is bad.
Also the front sway bar links might be bad.
Thanks,
I got Sensa Trac Struts.
The noisy part was the Sway bar link to the struts.
Thank you for the advice.
Belle Tire replaced the Struts and charged labor only $60 for two. Alignment is separate. They did a good job
frank_haren
Sep 26, 2009 06:01 PM
