MAJOR hesitation issues
Old Aug 12, 2011 | 03:23 PM
freq's Avatar
Default MAJOR hesitation issues
I'm having some major hesitation issues.
Whenever I put my car under load it starts missing.
It gets worse, the warmer it is: At night when it's in the 60's, I have to close to floor it to see the problem. But in the afternoon when it's in the 90's, when it's at its' worst, anything above 1500 rpm on a level road will cause it to start missing. Give it more than 1/4 throttle and it'll miss so bad that it stalls and shuts off.
Any ideas?
I've got a 98 s70 glt
Old Aug 12, 2011 | 04:05 PM
What have you done to cure the problem?
Old Aug 12, 2011 | 04:19 PM
freq's Avatar
So far, other than ask the forum for assistance, nothing. I'm on my way to get a code reader as my check engine light is on.
Old Aug 12, 2011 | 08:20 PM
gdog's Avatar
Pulling the codes is always a good start... when was the last full tune-up (i.e. stage0)? That may just fix it.
Does higher heat also correspond to higher humidity? If so, then suspect secondary ignition break-down; that could mean anything between the coil and the spark plugs.
winters-wolves
Mar 15, 2018 01:00 PM
chad_m
Feb 10, 2012 02:56 PM
MaineVette
Mar 10, 2011 07:44 PM
freq
Feb 2, 2011 01:58 PM
vester_72
Oct 14, 2005 10:30 PM
