Used S70 Issues - Major/Minor?
Old Oct 13, 2005 | 05:10 PM
vester_72's Avatar
Default Used S70 Issues - Major/Minor?
I bought a used S70 from a reputable dealer (Acura dealer) here in Chicago - took it to Howard Orloff Volvo for a full checkup - here is the list of issues they identified:
I was wondering how urgent these are to get fixed - they are LOT of $$ and I cannot do it all at once:
Issue Cost
Air Pump - emissions: $856.00
Spring seats front springs: $525.00
Engine Mount: $171.00
Air guide/radiator protector: $145.00
Front brakes - rotors and pads: $595.00
Right-front wheel bearing: $439.00
Also, if anyone knows a good place to get this fixed at that will not charge so much, please let me know.
Thanks,
Jason
Old Oct 13, 2005 | 09:49 PM
Default RE: Used S70 Issues - Major/Minor?
These are the order I would fix them in.
Front brakes - rotors and pads: $595.00 Major important to stop.
Right-front wheel bearing: $439.00 Needed so the right front wheel doesnt lock up.
Engine Mount: $171.00 Not sure which one but pretty much only causes vibration.
Spring seats front springs: $525.00 Makes a popping noise over bumps is pretty much all they do when bad.
Air Pump - emissions: $856.00 Yes it is emmisions related but can run fine without it.If you have inspection in your state then you might need to do it earlier.
Air guide/radiator protector: $145.00 Helps protect and guide air into the radiator. But not needed this minute.
Old Oct 14, 2005 | 12:48 AM
satchmodog's Avatar
You are getting hosed on that brake job.
Old Oct 14, 2005 | 10:02 PM
ORIGINAL: satchmodog
I see that now as well I wasn't really paying attention to the price just what it was.
It should be around $369.00 or close to it.
Old Oct 14, 2005 | 10:30 PM
reg's Avatar
reg
.............appears that the Volvo dealer is attempting to make up for the loss of sale from the Accura dealer.....................
R.
HildaTheBrick
2001-2013 model year V70
Mar 30, 2013 08:54 PM
alCanister
Jun 17, 2012 11:02 AM
nextproject
Dec 14, 2009 12:39 PM
bnuk013
Nov 2, 2006 10:12 PM
mjd
Apr 20, 2006 01:44 AM
