More questions about my new s70
Old Dec 22, 2006 | 09:51 AM
jzajzz's Avatar
Default More questions about my new s70
as i mentioned earlier .. i just got a n s70 with about 145k miles on it...
- the gas pedal is stiff .. usually when i first start.. and at random spots while im driving... what could it be.. ih avent serviced it yet.. this is my 2nd day driving it...
- the TRACS OFF light is on... to be honest with you .. i dont even know what TRACS is .. can someone explain it to me...
im about to have AAMCO do a check on everything.. but i still would like to knwo what you guys think..
Old Dec 22, 2006 | 07:00 PM
Default RE: More questions about my new s70
What year is it?
If it is a 1998 have the throttle body cleaned.
Tracs is traction control if the wheels start spinning the computer pulses the brakes to stop the wheels from spinning.
Most likely the ABS module is bad.
Old Dec 24, 2006 | 02:03 PM
jzajzz's Avatar
ORIGINAL: tech
What year is it?
it is indeed a '98 ... so is this thing common among 98 s70's.... .how much is it to get the throttle body cleaned?? ...
and if you dont mind can you explain how the throttle body afffects the gas pedal to make it stiff??
Old Dec 24, 2006 | 05:24 PM
It should cost less than $100.00 to get it cleaned.
The throttle body gets alot of carbon build up on it.
If you release the throttle pretty quick the throttle plate gets stuck in the carbon. Making the pedal hard to make it move again.
It might also be a cable.
But the dirty throttle body is usually the cause more than the cable.
Old Dec 25, 2006 | 12:37 AM
jzajzz's Avatar
ORIGINAL: tech
I see... but why did you ask about the year 98 ... is it more common with the 98 model?
thanks by the way ...
Old Dec 25, 2006 | 12:45 AM
The 1999 is fully electronic. Does not have a throttle cable.
Phil 850
Jul 25, 2012 10:01 PM
gordon368
Jun 6, 2009 03:01 AM
scandalo
Sep 21, 2007 06:50 PM
knight rider
Dec 30, 2004 01:11 AM
