Obdii code 1237.......
Old Feb 24, 2009 | 09:28 AM
d2jreality's Avatar
Default Obdii code 1237.......
Does any one what that code means. I cant seem to find any info on it. Its a manufactor code for a 99 S70 T5. My book doesnt show info. By the way my Volvo just hit 250,000 miles!!!!! Hell YA. Any response will be appreciated. Thanks.
Old Feb 24, 2009 | 04:17 PM
jdp6000's Avatar
If its P1237 thats for the Turbo control Valve.
Jim
Old Feb 24, 2009 | 06:57 PM
If that is the code I would check all the vacuum lines.
Old Feb 26, 2009 | 07:51 PM
d2jreality's Avatar
the code is coming up p1237. i thought it had to do with the fuel pump?
Old Feb 26, 2009 | 08:02 PM
s70_t5_1999's Avatar
turbo control. Maybe the lines, but in my case the actual valve was bad. I installed the ipd heavy duty valve and my car is actually a lot quicker now. you should look into it if you need one.
Old Feb 27, 2009 | 01:23 PM
d2jreality's Avatar
which valve is it?
Old Feb 27, 2009 | 04:17 PM
its the turbo control valve. its mounted near the air filter box and has 3 hoses and an electrical connector attached to it. easy fix - i did it myself.
Old Mar 1, 2009 | 10:29 AM
d2jreality's Avatar
how much are they about?
Old Mar 1, 2009 | 12:08 PM
89.95 http://tinyurl.com/ipdtcv
but you can get a normal quality one cheaper somewhere else
trooperone
Mar 6, 2009 05:21 AM
Eple
Aug 30, 2008 06:05 PM
tarheel
May 31, 2008 02:04 PM
lawlessbrown
Jul 24, 2007 12:54 PM
IROLL
Nov 7, 2005 09:00 PM
