oil pan o-ring replaced, but still ticking
There are 2 schools of thought on that.
1. It will clean all the channels, followed buy a good motor oil, proper pressure and lube will be back up into the lifters and rockers.
2.It will loosen up chunks that will block these passages. The follow up to this thought is: to run a thinner oil and change it often, Thus getting the same result as #1 over time.
OK give that a shot.
The newer S70's that have the cartrige filter have 2 more o-rings than the earlier cars and many people forget to change them.
thoroughbred
Jan 15, 2008 10:19 AM
