Oil pan o rings replacement question
Hi Folks,
I'm half way through changing the O rings in the oil pan using the instructions placed on here by tech. (due to low oil pressure message at low rpms)
I bought the O ring kit from Volvo and it came with these gaskets. What in the world are they for?? I found the 5 O rings I need to replace but have no idea where the 4 gaskets go that were included in the kit. I got the pan off right now, so I was wondering if anyone has any idea before I put it all back together again? Tech?
Is your car a turbo car?
The kit is a kit for all 5 and 6 cylinder motors.
The gaskets are for replacing the turbo return line o-ring and gasket.
The gaskets are only used for that.
If it is a Non-turbo it will only use 3 o-rings and that's all.
It will use the pick up tube one and the 2 for the oil pan.
thoroughbred
01-15-2008 10:19 AM
